Configures the TE metric value for the RSVP-TE interface specified by the vlan_name argument.
value | Specifies a value for the RSVP-TE metric. |
vlan | Specifies that the RSVP-TE metric is configured for a specific VLAN. |
vlan_name | Identifies the VLAN for which the RSVP-TE metric is configured. |
The associated default IGP metric.
The TE metric can be any unsigned non-zero 32-bit integer. The default value for the RSVP-TE interface is to use the associated default IGP metric. The TE metric is exchanged between OSPF routers and is used in the calculation of the CSPF topology graph.
The following command configures an RSVP-TE metric of 220 on the specified VLAN:
configure mpls rsvp-te metric 220 vlan vlan_10
This command was first available in ExtremeXOS 11.6.
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.1.1 Licensing Guide document.
